Created vs Resoved items - Problem only on February
Ariel Milani May 11, 2020
I have a problem with the Created vs. Resolved items, only in February, in the other months the metrics are being displayed correctly. I think this problem is related to the number of days in that specific month. Creating the query based on the other months, the tickets are displayed. Any idea?
Ariel Milani May 22, 2020
anyone?
Jack Brickey
Can you provide more info? what precisely are you seeing in Feb and why is it inaccurate? Can you provide your filter?
In my filter, you can see items created and resolved in February. The same problem occurs if I select a project.
That jql filter is just: "Project = Name" and as you can see there are data there. ( the date filter (created) was add just to screenshot):
and the chart configuration:
Matheus Balestri dos Santos June 17, 2020
I have this same problem with all issues of all projects.
Apparently the problem is on February 14, I have issues created and resolved that day that don't appear on the chart.
Ariel Milani June 17, 2020
Verifica se os tickets do Jira estão com a data de resolved preenchida. Para isso ser feito automaticamente é preciso ajustar no seu fluxo.
Estão, tanto com a data de resolução quanto o campo "Resolução"
O filtro usado, contempla todos os itens q deseja exibir?
Eu acabei abandonando essa solução e como não posso contar com algum plugin de reports, faço as querys e com os resultados monto os graficos no excel
Sim, basicamente coloquei summary is not empty para pegar todos os itens da instância que tenho visão, e mesmo assim aparece com 14/02, feveireiro ou primeiro trimestre com 0 itens. Provavelmente por algo nesse dia que faz quebrar o gráfico.
Provavelmente vou ter que partir pro excel também, obrigado!
