Creating a project with shared configuration does not copy the Project type
Brian Parris April 13, 2018
Using JIRA Software Cloud
When trying to create a new project with a shared configuration, all of the schemes are copied but the new project that is created from the shared configuration is a basic project instead of a scrum project like the original.   Seems like a bug. Any recommendations?
Deleted user April 16, 2018
Hi @Brian Parris,
Could I clarify with you what functionality are you missing in the new project (Basic Project) that is present in the existing project (Scrum Project)?
Brian Parris April 16, 2018
The Picture of TestProj (top)is the newly created project.  The Project FIL (bottom) is the configuration that I copied.  Notice that the TestPRoj does not have a backlog or Active sprint selections.  nobacklogorsprint.JPG
HI @Brian Parris,
That is expected behaviour as boards are not copied over when you share configurations.
Here is a link to set up a new board on a project
Bingo!   Thanks for the help.
Glad I could help
