Custom Field configured as not Required but need to make mandatory for another Project
Alok Bhargava July 29, 2018
Short statement of challenge: Custom Field configured as not Required but seek to make mandatory on a specific Project's Create Issue screen
I have a Custom Field with a Field Configuration where it is not a Required field so that it can be optionally used by Projects.
However I have one Project where I would like it's use to be Required.
My ideal solution would be to have the Create Issue screen for the Project require that field to be entered.
So my question is:
Is it possible for a Custom Field to have a Field Configuration where it is not a Required field, but force a Create Issue screen for a specific Project that uses that field to require that field to be set?
Thanks!
Nic Brough -Adaptavist-
July 29, 2018
Give the two projects separate and different "field configuration schemes".  In one scheme,  make the field mandatory, in the other, it should be optional.
Thanks Nic!  Let me give that a try.
