Greetings -
I am having an issue creating a script in Behaviours that allows me to pass the pulldown list selected item to my new task I create under the same issue. See illustration below. Custom Field name is Accounting Category (its default is TBD) - I want to pass the Operating Expense choice.
Here is the screen shot of the behaviour set up.
Here is the full script
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
def accountingCategory = getFieldById(getFieldChanged())
def accountingCategoryValue = accountingCategory.value
if (!accountingCategoryValue){
return
def accountingCategoryIssueKey = accountingCategoryValue.toString().tokenize(":").last()
def accountingCategoryIssue = ComponentAccessor.issueManager.getIssueByCurrentKey(accountingCategoryIssueKey)
def selectListCustomField = ComponentAccessor.customFieldManager.getCustomFieldObjects(accountingCategoryIssue).findByName("Accounting Category")
// could not find custom field with name "Accounting Category" on the accounting issue - do nothing
if (!selectListCustomField) {
return
def selectListValue = (accountingCategoryIssue.getCustomFieldValue(selectListCustomField) as LazyLoadedOption)?.value
def optionId = ComponentAccessor.optionsManager.getOptions(selectListCustomField.getRelevantConfig(accountingCategoryIssue)).find { it.value == selectListValue}?.optionId
getFieldByName("Accounting Category").setFormValue(optionId)
any help would be greatly appreciated.
Hello Steve,
Were you able to solve your issue following Adaptavist recommendations?
You can use the post function in this article as a template for your need:
import com.atlassian.jira.issue.IssueFieldConstants
import com.atlassian.jira.issue.fields.FieldManager
// the name of the field whose value we want to copy from parent to subtask
final String fieldNameToCopy = "Component/s"
FieldManager fieldManager = ComponentAccessor.fieldManager
if (!issue.isSubTask()) {
return
def fieldToCopy = fieldManager.allAvailableNavigableFields.find { it.name == fieldNameToCopy }
if (!fieldToCopy) {
log.info "Could not find field with name $fieldNameToCopy"
return
def parentIssue = issue.parentObject
def fieldToCopyId = fieldToCopy.id
switch (fieldToCopyId) {
case fieldManager.&isCustomFieldId:
def customField = ComponentAccessor.customFieldManager.getCustomFieldObject(fieldToCopyId)
def linkedIssueCustomFieldValue = parentIssue.getCustomFieldValue(customField)
issue.setCustomFieldValue(customField, linkedIssueCustomFieldValue)
break
case IssueFieldConstants.COMPONENTS:
issue.setComponent(parentIssue.components)
break
case IssueFieldConstants.FIX_FOR_VERSIONS:
issue.setFixVersions(parentIssue.fixVersions)
break
case IssueFieldConstants.AFFECTED_VERSIONS:
issue.setAffectedVersions(parentIssue.affectedVersions)
break
default:
issue[fieldToCopyId] = parentIssue[fieldToCopyId]
Let me know if this information helps.
how are you triggering the new task creation?
Either the pulldown create new sub-task or click the plus sign in the issue.
instead of behavior you should try using a Issue Create/Update Listener to copy the value from the Parent to the Sub-Task.
Behaviors are loaded on the current form, so might have to write additional code to get the issue context where the creation is triggered.
I am new in customization Jira with the adaptavist plugins. So I need to do a listener instead of behaviours?
here is how it will look
also you get get some solution here : https://library.adaptavist.com/entity/create-a-sub-task-when-parent-issue-has-a-specific-label
After talking with Adaptavist - they told me to use a behaviour instead of a listener - so Not sure how to proceed here.
They are the experts. I would follow their inputs and they should have script samples too.
