Custom Jira Charts using Chart Macro?
Ben December 23, 2024
Hello all,
Has anyone had luck using the chart macro with a jira filter and specific columns in the table to make a chart out of it? Specifically utilizing group bys.
Stiltsoft support
Hi @Ben ,
If you are talking about Confluence and creating charts based on the Jira Issues macro, we can suggest trying the app that we develop - Table Filter, Charts & Spreadsheets for Confluence.
You may wrap your Jira Issues macro in the Pivot Table macro and group your issues as you wish. Then you may use the Chart from Table macro and visualize the result.
If you are not familiar with the app, please book a call from the team - we'll show everything live.
Ted Nieblas
Hi @Ben
Can you tell us which chart you are using specifically? A screen shot would be very helpful.
I am looking to create a grid that has each week as columns, each Team (in Jira) as rows, and estimated timer remaining as a value. Don't know if that helps.
Ted Nieblas
Hi @Ben
There is no Group By function in JQL. The only way I can see this being accomplished without looking for a specific app that supplies this (don't know if one exists), would be to create a custom field containing the first day of the week (JQL "startOfWeek()"). You can then use the two dimensional filter statistics field to display them (not sure this will achieve the view you desire).
Let me know if this works or at least gets you closer to your goal.
