We are using JIRA 8.5.1 and we have installed ScriptRunner Add on version 5.6.7.1.
I want to bulk update statuses of number of sub-tasks basis on 2 conditions using ScriptRunner.
If someone can provide me query basis on below criteria that would be helpful. Or how can this be achieved using ScriptRunner. (I am a bit novice on ScriptRunner)
Requirement example:
Update to new sub-task status of "TYU" for sub-tasks of Current status = abc, xyz and parent task status = MNO, EFG
I have >200 sub-tasks for which this activity is to be done.
Hi @Kaushik Patel ,
If I'm understanding it correctly, the following query would return the subtasks you need to transition:
type = Sub-task AND status in (abc, xyz) AND issueFunction in subtasksOf("type=Task AND status in (MNO, EFG)")Should you need to include status names with a blankspace, enclose them in single quotes (ie: 'In Progress').
Then, you may transition to the TYU status in one go through a Bulk Change operation (if the transition is available from abc and xyz statuses. Otherwise, it would require two distinct queries, one for each of those statuses).
Hope it helps.
