Hello everybody, we build up an test project to get familiar with jira and start customizing fields and workflows. When we finished our testing, we wanna start with a clean project. Is there a way to migrate fields, configurations, workflows... to the new and clean project?
It depends on the project type.
For team-managed projects - no. There's no way to transfer configuration between projects.
For company-managed projects - yes, but it's not a migration. Most of the config of a company-managed project is done with global "schemes", so you'll have a field configuration scheme, a permission scheme, an issue type scheme, a workflow scheme and so on, that define the configuration of the current project. When you create your new project, instead of using a template, tell it to "share with existing project" and you'll find it takes on the schemes that the first project has. (Even if you create from a template, you can always change the schemes to shared ones later)
