Dashboard shared with project, but not visible for all groups in project
Sandra Meessen
Hello, I have a dashboard shared with project A. On the dashboard are 5 different filters, also all shared with project A. I have 2 users:  user1 and user2. User1 is member of several project roles in the project and can see the dashboard correctly, user2 is only member of projectrole "users" and he get's several errormessages on the different filters/gadgets:
- on the "filter results": errormessage "The filter configured for this gadget could not be retrieved. Please verify it is still valid on the issue navigator."
- on the Pie Chart gadget: errormessage "Unfortunately, one or more of your preferences are now unavailable. Please update your preferences, or remove gadget by clicking delete from the title bar above.".
I use both users on the same laptop, same Jira instance, same browser (version). What can be the issue? Thanks for the help.
Moses Thomas
@Sandra MeessenMake sure that user's  have access  to  filter,  ie  it's not  set to  private.
Sandra Meessen
Hello Moses, I checked: both dashboard and all used filters are shared with "project" (so all groups in projectA). What can be the problem?
Moses Thomas
@Sandra MeessenCheck  this, since you  are the one that created this filter it should appear on  your favorite filters  click  it the filter and then go  to  Details  at  top of the search  boxSelection_005.pngThen choose  project, as shown, Click  the Add  then  Save
Now users /groups in  project A should have Browse project permission, i  think  this should work.
Best!
Like # people like this
Sandra Meessen
This is all in place for all used filters in the dashboard. That's why we don't understand what is happening. Some groups see the filterresults and some don't.
Moses Thomas
@Sandra MeessenI suggest  you  check  those groups  that  don't see,  make  sure they  have "browse project  permission"  in the permission scheme for this project A , it should  work,  please very  this.
Sandra Meessen
Yes, that's also in place for specific groups.
Moses Thomas
@Sandra Meessen
One more thing  to  check  verify that users  are in  the group    which  you  have given browse project permission in project  A.
Sandra Meessen
That's also in place.
Moses Thomas
OK.
 So create a new board,  create new filter,   and share it again according to all dependencies taken into  consideration in our previous talk , and  see just to  verify  that is a bug or not
best!
Sudhanshu Pant
June 7, 2018
I am also facing the exact same issue. Sounds like a bug.
Like Allison Phillips likes this
Donna Hageman
June 29, 2018
I'm also seeing this. I just received a user issue saying he can't see the dashboard gadgets (he added the dashboard as a favorite but all the gadgets say "Unfortunately, one of more of your preferences are now unavailable.  Please update your preferences, or remove gadget by clicking delete from the little bar above") but others on his team can.
The dashboard was created by his manager so I checked to make sure the filters were shared and they were. The filter is shared with a user group.  I then verified that the user was part of that group and he is.  Others on his team can see the dashboard but he cannot.
Andrea Bocchetti
October 18, 2018
Could please Atlassian Team suggest a resolution for this issue?
Dominic Parr
November 1, 2018
I am having exactly the same issue.
Rajendra Bandiwadekar
May 30, 2019
Though the owner has shared the Dashboard but the user has to do following steps:
Go to Manage Dashboard,
click on search link,
Enter the Exact Dashboard name,
select owner name
select shared with. ( project ,  select project from dropdown, All)
Make it favorite
Deleted user June 11, 2019
Yes, This worked. Thanks Raj
Arunava Roy
August 11, 2019
This doesn't work for me. My dashboard is shared with a Group. The users can see the dashboard, but they can't view the gadgets on it.
All the previously suggested points above are in place.
Here's my error:
Allison Phillips
I am also seeing this for a dashboard rendering a pie chart that draws from a filter. The dashboard and filter have 'My Organization' level permissions and some logged-in users aren't able to see it.
7 votes
Deleted user February 20, 2020
I think this is what Moses and Raj suggested above, but I'm reframing it in a way that makes more sense to me:
Your gadgets and dashboard may be visible, but those based on filters you have saved in search will be blocked because the filters themselves are set to private by default. To fix this:
1. Click the Issues tab.
2. Scroll down to and select "Manage Filters".
3. Click the gear wheel next to each filter used in your gadgets and add users as needed (jira-users is the broadest and offered by default).
Your gadgets should now appear in the relevant dashboard for any users you shared the filters with.
Alan McDermott June 5, 2020
Worked - clearly explained. Thank you Jeremiah.
Also, Attlasian, why is it not plausible to present users trying to share private filters with that information so they know what's causing the issue and how to fix it?
jsiu April 28, 2021
Thanks for this description. Helped with fixing the issue for my team.
Robin Marshall
November 28, 2018
Does this really need to be done for all Filters, or can you set defaults for Filters or open them all up in bulk somehow?
July 18, 2019
Yes we need to do this for all the filters i believe
