hello!
I'm creating a dashbord that includes more than one project ( I created a filter with 2 projects) to keep track of the status of all tasks. But when I use the pie chart, the categories "pending tasks" (tarefas pendentes), "completed" (concluido) and "in progress" (em andamento), appear repeatedly, as if I were separating by project when I want a unified view. Here is the image of my problem (it's in Portuguese). Do you know how to help me?
I need a unified view of the Status of all projects. This is also happening at the following up project
Welcome to the community, @Catarina Dowsley.
I am Marlene from codefortynine.
Are the project in the filter a team-managed and a company-managed project? If yes, the issue could be related to that. Team-managed and company-managed issues statuses and workflows are technically something different, even if they have the same name.
On the left side of the screenshot below, you see the Jira standard gadget with duplicate issue statuses. On the right side, this is the Pie Chart gadget of our app Quick Filters for Jira Dashboards. Our app automatically matches statuses which have the same name.
Hello @Catarina Dowsley and welcome
You have the possibility, in the gadget configuration, to select the filter you want to use.
I suggest you createa new filter "Project in (XXX, YYY)", and select it in your gadget.
Let me know if it helps you
Hello! @JM Perrot ! Thank you so much for your time to help me.
So, I have already done this. I'll show you:
If I look at my filter by In progress status it will show all of my 8 itens in progress. That is perfect. I do have 8 itens in progress when combining my 2 projects in this filter.
My problem is: when I go to my dashbord it divides these 8 items in 3 and 5 (Em Andamento means In Progress in portuguese):
I want to see 8 itens in progress and not 3 and 5. In fact I do have 3 itens in a project and 5 in the other one, but I created a filter to see them together. I don't understand why Jira is not unifying them if they belong to the same status.
Hmm strange, can you share your filter here?
With my filter, I don't have this issue :
And my filter is just : project in (DEV, INFRA)
Do you use the same status (there is no space at the end of one or something like that ?)
Hi, I am also having similar issue i want to create a dashboard with multiple projects and show the status of one type in a single column for all the projects. It is creating same name columns multiple times like one for each project. Any suggestion?
