Default Subtasks when creating an Issue
Tara Asch October 3, 2018
Is it possible -- without buying a plugin -- to have 4 subtasks that are part of the template for the initial issue creation?   I.e. I  open a ticket for a new Client Implementation and I have four subtasks that are already in the ticket for assigning to four other teams that have tasks outside of the Jira workflow.
Mohamed Benziane
If you want to create automatically 4 subtask when a issue is created you will need a plugin. I did it with bob swift addon
Regards
Ah. Okay - thanks I"ll check it out.
Best,
Tara
