when creating a project I would like to add components (15) that we use to manage projects.
I use hosted Jira environment.
1) when creating a project I would like to see the components added automatically.
2) Can I copy components from one project to another?
Best regards,
Gert
Thanks for your reply!
how can i install the app in de hosted jira version?
This app is not available for jira cloud. And i think there is now way out for you to copy comments between projects.
maybe there is a solution to copy a project in a way that it also copies the components?
I think that might work and you will get all the available issues, components and all other configurations in the project.
Hello @Gert Kornet
As far as I know there is no straight forward method to copy components between projects and components cannot be added automatically.
But you can use Clone Project for Jira plugin to copy the components to other projects. Click the link to know more about plugin
