Dependencies view in JIRA Roadmap for links other than blockers
Abhiram Rao July 8, 2022
Hi Al,
Quick question around showing the Incoming and Outgoing dependencies.
I understand when you have JIRA issuetypes which are linked using "Blocked by" or "Blocks" it shows up in the Incoming and Outgoing dependencies.
However, can we get the issues displayed when we link using "dependent on", "depends" etc?
Abhiram
Walter Buggenhout
Hi @Abhiram Rao,
In your general Advanced Roadmaps settings (Plans > Settings > Advanced Roadmaps Dependencies) you can configure which link types you want to include and how they should behave:
Hope this helps!
Yes.. It did help.. Thank you so much.. Appreciated..
This makes the Roadmap view much more meaningful. :)
Rob Horan
July 18, 2022
Wait wait wait wait wait wait wait wait wait wait wait
You can get real dependencies in AR instead of this 'blocks' BS?
Why is this not documented?  Why is it not being shouted from the mountaintop?!
Seriously, does this provide the ability to get dependencies like in Structure and BigPicture?
Can it autoshift start and end dates?
Like Kate Hakes likes this
