Dependency between issue field and status
krzysztofzarebski May 20, 2022
Does anybody knows, there is possibility to set some kind of dependency between unfilled up field and status transition? I have a case, that I want to force user to set FixVersion before he/she close an issue.
3 votes
Fabio Racobaldo _Catworkx_
Hi @krzysztofzarebski ,
this is a common feature. You need to setup a validator for your specific transition in which you can define mandatory fields. Keep in mind that mandatory fields should be present on the related transition screen.
Here a guide how to setup mandatory fields https://confluence.atlassian.com/jirakb/make-custom-fields-required-in-a-workflow-transition-in-jira-server-691011903.html
Hope this helps,
Fabio
Fabio, that's the point! Thank you for a quick answer!
Like # people like this
