In project that used IssueCollector, if i add a context to Description field, the text is duplicated in the issue collector view (One as Text is editable , The other as wiki render is not editable)
This is the configuration of the collector
i hope you can help
could you please share the version of Jira you are using? This sounds like a bug to me and might be reported to Atlassian directly instead of this forum.
From the configuration perspective, it seems to be a valid configuration and I cannot see any hint for using the field context in the HTML/JS logic.
Stefan
Hi @ranck
could you please share how you have created the Issue Collector? Usually the collector is some kind of HTML and JavaScript where all that information is used.
Maybe this can show why this happens.
Also, could you share the version of Jira you are using and where you embed the Issue Collector?
Stefan
