Difference between JQL resolution = Unresolved and resolution = "\"Unresolved\""
Jongho Jung
One of my customer asked me a question about the different results in using JQL belows :
  • assignee = "abc@abc.com" AND resolution = Unresolved
  • assignee = "abc@abc.com" AND resolution = "\"Unresolved\""
Please let me know the difference of above two JQL.
Regards, JJ
3 accepted
4 votes
Walter Buggenhout
Hi @Jongho Jung,
The first JQL is the way to find all issues where there is no resolution filled out. Unresolved is a reserved keyword that lets you identify all open issues. The second one would return literally the issues where the value of the resolution is "unresolved". The backslash is used in JQL to escape special characters. However, with the resolution field, that does not make much sense. It would be a bit of a contradictio in terminis (using a field the says how something was resolved and then saying it isn't).
Hope this helps
Jongho Jung
Thanks for your answer.
Muhammad Moazzam Hassan
November 6, 2023
Resolution field have pre-define values like a Single Select Dropdown Field,
The first query is correct and will search the issues whose resolution is empty.
The Second quey is wrong because this notation is used to search text-based fields and this notation will search the text which exactly contains that phrase.
Jongho Jung
Good answer, thanks.
Sanjen Bariki
November 6, 2023
Hi @Jongho Jung ,
Welcome to Atlssian community.
Please find the answer below inline.
It means where the resolution field has not been set yet, and In other way which is unresolved issues in many issue tracking systems.
This might not work as expected in the systems as the value of resolution is typically stored without quotes. Resolution defined globally So don't need to user "\"abc\""
We need to use quotes in the comment and other text values not for here.
Sanjen
Jongho Jung
Thank you.
I can explain the difference to my customer.
Murat Seven
November 6, 2023
Hi @Jongho Jung and thanks for your question.
You can following page might help.
Hope this helps.
Best,
Murat Seven
PREMIUM Trial
