Difference between administrators and administrators(migrated) in Jira Cloud
Kavitha K June 23, 2021
Recently we migrated some projects from jira server to jira cloud using cloud migration assistant. And while adding people to a particular project I could see two options as administrators.
1. Administrators
2. Administrators (migrated)
What's the difference between these two?
And people who have added to these roles will they be able to edit workflows?
Phill Fox
Hi @Kavitha K
The clue is in the naming of the second group
this is the administrators group that existed on your Jira server instance and rather than replace the existing Cloud administrators group with unforeseen circumstances it is migrated and flagged so that you know.
Now to be able to answer the question about who can edit workflows requires you to look at the permissions for the two different administrator groups.
Personally I would look to do a clean up exercise as follows (the perfect opportunity to check and make sure there are no folks with inappropriate permissions).
1. Make sure the Cloud administrators group has all the correct permissions for that role.
2. Add members from the Migrated administrators group into the Cloud administrators group as appropriate
3. Remove any members from the Migrated administrators group that should no longer have those permissions.
4. Delete the Administrators (migrated) group.
Kavitha K July 1, 2021
Thank you @Phill Fox !
FREE
