Difference between "project" and "Goals" in Atlas
Nicolas Mayans
June 27, 2024
Hello community! I hope they go very well. I want to consult you regarding the correct use of Atlas. Specifically in the difference between Project and Goals (not a jira project but the one created in Atlas). I have this confusion about how it should be treated, if the atlas project involves several Goals or the Goals can contain several projects. In addition, this understands their hierarchies among other things. I read the documentation but I can't clearly close the concept. Thank you so much!
Annie_DevSamurai
Hi @Nicolas Mayans
Welcome to the community. I'm happy to help clarify the concepts of Project and Goals in Atlas.
Project:
  • Definition: a collection of tasks that need to be completed to achieve a certain outcome
  • Scope: Defined scope, timeline, and deliverables.
  • Usage: Use projects to manage specific initiatives with clear deliverables and timeline
Goals:
  • Definition: High-level objectives or outcomes the organization or team aims to achieve.
  • Scope: Broader vision, encompassing multiple projects and initiatives.
  • Usage: Use goals to define strategic, long-term outcomes that align projects and initiatives toward common objectives.
You can find more detail here
Here's an example:
Goal: Increase Market Share by 10% in the Next Year
  • Project 1: Launch new marketing campaign
    • Tasks: design materials, etc...
  • Project 2: Expand product line
    • Tasks: research market needs, develop new products, etc...
I hope this may help!
Nicolas Mayans July 1, 2024
Annie, thank you very much! When you refer to projects, they are the ones that are created in Atlas and not in Jira, right?
Like Annie_DevSamurai likes this
Annie_DevSamurai
Yes, that's right! You can imagine that Atlas projects are about the big picture and strategic initiatives, while Jira projects focus on detailed execution and task management
FREE
