Difference between type and issuetype in JQL
Jack Nolddor _Sweet Bananas_
Someone can tell me the difference if any between type and issuetype field on JQL?
I have same question with key and issuekey fields..., are they different in any way?
8 votes
Nic Brough -Adaptavist-
August 4, 2019
It's not well-documented, but there are a handful of "aliases" in Jira.  Key is an alias for issuekey, and type is an alias for issuetype.  You've spotted the two main ones!
The aliases can be clobbered - you can create custom fields with the same name which then become the first place Jira looks when you type in the alias, but I'd try to avoid doing that in every case, as it just confuses your humans.
Cristian Rosas [Tecnofor]
October 4, 2019
"Your humans"
Like # people like this
Matt Doar
I use "issue type" when I want to avoid confusion. Just like I say "Jira project" instead of "your company project".
To see all the aliases that exist go to /rest/api/2/field as an admin, and look at the clauseNames for each field.
I found the following aliases
[u'issuetype', u'type']
[u'remainingEstimate', u'timeestimate']
[u'updated', u'updatedDate']
[u'originalEstimate', u'timeoriginalestimate']
[u'id', u'issue', u'issuekey', u'key']
[u'created', u'createdDate']
[u'due', u'duedate']
[u'resolutiondate', u'resolved']
Alexey Matveev
August 4, 2019
There is not difference.
