Disabled Comments for specific project role
Tomáš Štalmach September 28, 2014
I would like to disable comments for specific project role in group of issues in specific WF status.
I found I have to define something like that : "jira.permission.comment.projectrole=10200" and value: "false" in Properties of specific Workflow status.
After I did this, all affected issues in this status, for example Closed, are unavailable. There is only error message "There was an unexpected error while loading the issue."
Have someone any idea, what I´m doing bad?
Tom
Jobin Kuruvilla [Adaptavist]
September 28, 2014
You can not do this. You can only restrict the functionality to a selected role. i.e. you can't remove the permission from rule 'X' but you can give the permission only to role 'X'.
For example, if you give the property as jira.permission.comment.projectrole and value as 10200, only users in role 10200 can comment on the tickets.
Krispijn Joseph
March 26, 2019
@Jobin Kuruvilla [Adaptavist]  Hi am new to Jira and im struggling to turn turn of comments for the user role clients that i made. Because i don't want the client to read the comments of the developer on a issue. I cant find the setting in Jira so I'm guessing it needs to be done the way you showed above.
How want to disable comments for the Role 'Client'?
Can you help me please?
where do I need to fill in jira.permission.comment.projectrole.1=10200 in Jira cloud?
how do i get the id of the role 'client'
Can you tell what everything stands for, what is?
  • jira.permission.comment.projectrole.
  • 1
  • 10200
Thank you very much!
Rudy Holtkamp
@Krispijn Joseph See this link.
Here a partial copy of that page.
 The property is of the form - jira.permission.[subtasks.]{permission}.{type}[.suffix] where:
  • subtasks is optional - If included the permission is applied on the issue's subtasks. If not the permission is applied on the actual issue.
  • permission - is a short name specified in Permissions class. Following are the permitted values as on JIRA 4.2
    admin, use, sysadmin, project, browse, create, edit, scheduleissue, assign, assignable, attach, resolve, close, comment, delete, work, worklogdeleteall, worklogdeleteown, worklogeditall, worklogeditown, link, sharefilters, groupsubscriptions, move, setsecurity, pickusers, viewversioncontrol, modifyreporter, viewvotersandwatchers, managewatcherlist, bulkchange, commenteditall, commenteditown, commentdeleteall, commentdeleteown, attachdeleteall, attachdeleteown, viewworkflowreadonly
  • type - type of permission granted/denied. The values can be group, user, assignee, reporter, lead, userCF, projectrole
  • suffix - An optional suffix to make the property unique when you have the same type added more than once! jira.permission.edit.group.1, jira.permission.edit.group.2 etc
Thank you! It helps me a lot!
