×Hi atlassian,
I have atlassian java listener plugin. I want to show input dialog box for during the issue event, such as <input type="text" > html tag. Is there a solution to do that?
For Note: I used JFrame for java, but it didn't work.
Sorry for bad English :)
Mamikon
hi @Mamikon Papikyan you can't do it by default. You would have to implement some mechanism which "listens" to event caused by listener. I will try to describe. There are two processes
Problem of this solution is performance. If you will invoke JS(JavaScript) action to often (once a second), it is 60 invocations in one minute for one tab of browser. If you have 500 users with 3 tabs opened, it is 1500*60 invocations per minute.
By the way, JFrame is Java SE technologi, you can't use it on web.
Thank you for your answer Martin. Sorry for late answer, but actually I want to get data from velocity. I have a listener plugin written java, So I be able to show dialog box using javascript in .vm file.
Here my velocity
#set ( $d = "$")
<script language="JavaScript">
AJS.${d}(document).ready(() => {
AJS.${d}('#cus-butt').click(() => {
var username = document.getElementById("username").value;
var password = document.getElementById("password").value;
</script>
<form>
<label for="username">Username:</label>
<input type="text" id="username" name="username"><br>
<label for="password">Password:</label>
<input type="password" id="password" name="password"><br>
<input type="submit" value="Login" id="cus-butt">
</form>
Now I want to send username and password value in my java listener . Let me to show you my atlassian-plugin.xml.
<atlassian-plugin key="${project.artifactId}" name="${project.name}" plugins-version="2">
<web-panel key="test25" name="test25" location="com.atlassian.jira.plugin.headernav.left.context">
<label key="Custom Issue Panel"/>
<resource name="view" type="velocity" location="button.vm"/>
</web-panel>
</atlassian-plugin>
