Displaying custom fields inside a Project
Supriya November 21, 2019
I created Ticket Number and Estimated Time of completion fields in JIRA. I am trying to add these 2 fields to show up inside all tasks for a specific project.  How do I do that?
I want these 2 fields to show up in this screen. I don't want these fields to show up for other projects.
Heiko
You  can add/create it to the specific project screen in your configuration
Thank you. Could you be more detailed on how I can do that? Is there a link that I can follow?
Heiko
Yes you go to the field configuration and create a new once then  with the fields you would have in the project on the next steps you create a field scheme and the last point is you go to the prject setting and ad the field schem to the project and delete the old one
