Do Jira has theard comment on an issue?
Tamar Peer April 20, 2023
Hey,
Is there an option to enable theard comments on a Jira issue?
Thanks!
2 accepted
Aron Gombas _Midori_
Threaded comments are not supported by the Jira Cloud features, but there is an app which implements them: https://marketplace.atlassian.com/apps/1217033/threaded-comments?hosting=cloud&tab=overview
Kelly Arrey
April 25, 2023
Hi @Tamar Peer We use the Ugubi Threaded Comments app mentioned above. It works pretty well.
Walter Buggenhout
Hi @Tamar Peer and welcome to the Community!
I assume your are asking about an option to reply to an existing comment and as such create a discussion thread?
If so, that is currently not possible. There is a feature request open for it though, that - while not on the short term roadmap - has been recognised as a valuable improvement. You can track it here: JRACLOUD-3406.
Hope this helps!
