I plan to move several issues that contain attachments from one project to another. I'm worried that the attachments will be lost during the move.
Hi Michael, yes they will persist. At least it does in Cloud and fully expect the same in Server/Data Center. You can always create a test issue and try it out too.
Same on Server - attachments are considered part of the issue and will always remain attached to their owning issue unless you actively delete them.
