Does Jira Work Management have screen schemes?
Julie d_Antin _Elements_
I would like to customize what appears on the create issue screen in JWM versus what is visible on the view and edit (similar to what can be done on JSM & JSW).
But I can't seem the find the option anywhere. I have been able to modify the fields in the issue directly from the project settings in the Work Management project, but when going into the system settings to try to find the screens specific to create/edit/view I am only seeing ones related to software or JSM projects.
So, does Jira Work Management have screen schemes? Is it possible to customize what appears on the create issue screen versus view/edit?
Is creating a Form a decent workaround?
Trudy Claspill
Hello @Julie d_Antin _Elements_
Are you working with a Company Managed project or a Team Managed project? That information will display at the bottom of the navigation panel on the left.
If you are working with a Team Managed project, those don't use any of the schemes. Schemes are used only in Company Managed projects.
If it is a Company Managed project, when you click on Project Settings you would see an option in the navigation panel for Screens, and if you click on that it would show you the Screen Scheme used by the project.
Ahhh, you're right, it's a Team-managed. But I would have sworn that I created a company-managed!
