The Fields i would require,
Looks like a business project with some custom fields which you need to build and put on the screens.
You will have to build these fields in Jira and you should be good to go.
Would you mind assisting me in how to go about doing this, please.
You can build a demo with all of that quite easily.
I am not sure what your question really is (especially what a "segment" might be)
It is our own SuccessFactors system that we use for client demo’s. Can we partition within Jira to separate from Projects a system to manage our demo's.
I still don't think I understand.
At a guess, do you mean you want to use Jira to manage demonstration sessions and/or systems? If so, then yes, you could create a new project (or several projects) that are dedicated to managing demos, totally separate to the other projects in your Jira.
Yes, to manage the demo sessions.
These are the fields i would require.
I'd probably start with the third business project - that's got a slightly more complex workflow than most (6 status rather than 3 or 4), so when you're editing the workflow, you've got more to update, rather than adding lots.
For the fields, it doesn't matter what template you use, you're going to need to add all of them.
When you say "third business project", what are you referring to? The Options of templates that i have when creating a new project in Silver Bullet are, refer to image below
You did not say you were on Cloud, so I assumed server, which has three project types defined for business.
The idea still stands though - pick a business project with the most complex workflow.
Sorry, new to this. Finding my way through without much assistance. Which template would you suggest i use?
Hi Nick/Krishnanand
Your assistance is appreciated. Do you have more info that you would be welcome to share on this topic.
Ugan
Not really, the question is a bit too vague. At this point, it is better that you experiment and learn what the various templates do. You should pick a template that sounds like it is closest to what you're going to be using the new project for.
what do you mean by demo systems?
Like @Nic Brough -Adaptavist- mentioned, you can create multiple project and designate them as demo project and build an integration with you SuccessFactor interface.
