Custom scripted field to show linked issues by link type
Paul Gryfakis July 11, 2020
I would like to create custom fields that represents inward and outward link types so we have better information than a singled 'linked issues' field with simple links.
For example:
I have 2 issues (A & B) - A 'blocks' B
I would like to have 2 fields "blocks" and "is blocked by"
  • Issue A  shows field 'blocks'  populated with Issue B
  • Issue B shows field 'is blocked by' populated with Issue A
Thanks in advance for help on this
JIRA: 7.13.12
Ravi Sagar _Sparxsys_
July 11, 2020
Hi @Paul Gryfakis
May be I missed something but that's what the inward and outwards description tells you.
However you can always display this information in a scripted field or may be a panel.
Take a look at this example.
Ravi
Paul Gryfakis July 12, 2020
Hi @Ravi Sagar _Sparxsys_  - Thanks for your quick response.  The example you sent over is also helpful. My goal is to have a custom field for each inward and outward connection so that it's clear how each linked issue is linked.
Let's say I want to report on Relates to, Blocks, Is Blocked By...., I'd have 3 custom fields.
A simple issue search could return:
Key, Summary, Priority, Status, Relates to, Blocks, Is Blocked by, Updated
SERVER
VERSION
6.15
