ECO Management in Jira
Eran Haskel October 25, 2021
We are looking for an application/plug for ECO management that will have also a BOM`s management /document version control/ Approval mechanism.
Nic Brough -Adaptavist-
October 25, 2021
Could you expand a little on your TLAs?  I'm not sure people will give you a helpful answer without knowing what they are (we might answer the wrong question)
Eran Haskel November 1, 2021
Sure, sorry, we want to create a procedure of (ECO)engineering change order and (BOM) Bill Of Material, to support the life cycle of products such as a (PCB) Printed Circuit Board or any other mechanical unit
November 1, 2021
Ok, why do you think you need an app for this?  What parts of your processes are not currently being done by Jira?  (Apart from "document control" - most people would do that in Confluence)
Thank you Nic
I need the following:
1. few approvals on each document.
2. Doc control and track changes (I will try Confluence)
3. Change request is issued, When the change is approved, new relevant documents must be issued with their respective version number changed.
4. When the change is approved, new relevant documents must be issued with their respective version number changed (these documents can be BOM, gerber and assy files, schematics, etc.).
5. After the approval additional people need to be notified about the change (engineering, operations, manufacturing).
Julie Maia
March 9, 2022
HI Eran, where you able to find plug in for this? I am looking to see if I can find something similar for my team.
Like Eran Haskel likes this
Eran Haskel March 10, 2022
Hi Julie.
I am using confluence application and it fit my needs.
Highly recommended.
Eran
Julie Maia
March 10, 2022
Thanks Eran, i will look into confluence!
Steve McDowall
December 1, 2023
@eran -- Hey Eran.. do you have any further information on HOW you accomplished this via Confluence ??  Is there some sort of plug-in / template or something for ECO management ?? I am not easily seeing how to do this "manually" -- Thanks!
