Hello Team,
I need your help with the below:
Assume the field "A" is required at the time of issue creation:
After creating an issue, if I click the Edit button, I will be able to pick the "none" value if the field is "list," as well as delete all of the text if the field is "Text," therefore it should not be allow for anyone to delete the value from the field using the "edit" issue button if those fields were required/mandatory while creating an issue.
Hi Gajanan,
how are you making the field required create?
