Enable Insight for Jira issues
eranz January 18, 2020
I would like to enable Insight for Jira.
In Add Custom Field I can't fine the Insight Object/s field.
Could you please let me know what i am missing?
Thanks, Eran
Jack Brickey
Hi Eranz, I don’t use Insight but wanted to check with you to ensure you have installed the addon.
Hi Jack,
Thanks for your answer.
Shure, the addon installed.
Eran
Jack Brickey
Thanks. I assume you are referencing the documentation and not getting the specified results? Assuming so I would start with their support. I did find some tutorials out there on YouTube but unsure if they are cloud or server. While they should be similar I do expect differences.
