Hi
I have multiple projects which are not next gen projects. I can't easily migrate them to next gen projects because I've not been able to retain the values in a custom field called 'acceptance criteria' when doing a bulk move. This is the first problem, and assuming this isn't possible, I have a second problem....
I have a next gen project where I'm creating a roadmap. I'd like to include issues from from the non-next-gen projects as 'child issues' of the epics in the next-gen project so that they appear on my roadmap.
I have succesfully included the next-gen epics in the backlog view of my non-next-gen project, but when I assign one of the issues from the non-next-gen project to the next-gen epic I get an error that says "PI-17 [The next gen epic] is not of the type Epic".
I assume this is because the next-gen epic type is not the same as the non-next-gen epic type, and I can't use a next gen epic in the non-next-gen issue's epic link field.
At the moment, I'm faced with the prospect of manually re-creating all my non-next-gen issues in new next-gen projects so that I can use them on my roadmap without loosing the info in my custom 'acceptance criteira' field.
You cannot add classic issues to a NG epic. They are a different beast altogether.
Thanks for the confirmation. This was my expectation. I'll abort my wild goose chase.
In which case I'm back to the issue of trying to bulk move tickets to a NG project whilst retaining the custom 'acceptance critieria' field.
Either that or manually recreating all my tickets in a NG project which will be a pain. ☹️
