Error adding a component as a post function using Scriptrunner on Cloud
Jade Stephen September 2, 2020
We are using Jira Cloud with the most current version of Scriptrunner.
I am trying to add a component to a production support issue as a post function with scriptrunner on create. I have added the following script:
     issueInput.fields.components += [[
Im getting the following error:
2020-09-02 15:26:40.668 ERROR - No such property: issueInput for class: Script1 on line 1
2020-09-02 15:26:40.785 ERROR - Class: com.adaptavist.sr.cloud.workflow.RunScript, Config: [className:com.adaptavist.sr.cloud.workflow.RunScript, uuid:3b0cd080-f87b-4f3d-bdc6-682713f6bd31, description:Add Support Issue Component, enabled:true, condition:issueInput.fields.components += [[
]], executionUser:ADD_ON, accountId:5d28a2eb831d7b0bcfbe559a]
Any suggestions?
I'm really new to Scriptrunner and having a hard time, so any help is very appreciated.
Ste Wright
Hi @Jade Stephen
What is the outcome you're trying to achieve with the script?
Adding a component during creation might be possible to achieve without a script, using Automation. If you can provide the specific scenario, I'd be happy to try and find a solution :)
Ste
Jade Stephen September 8, 2020
Hi Stephen,
I am trying to automatically add a component to a support issue when its created for tracking purposes.
We have a board that will track these issues with an expectation that they will be moved to other projects during their life cycle.
Ste Wright
Hi @Jade Stephen
It's possible to do with Automation if this helps?
For example, to add a project-level rule for this:
  1. Go to Project Settings > Automation
  2. Press the blue "Create Rule" button
  3. For Trigger, choose Issue Created
  4. Add a Condition, Issue Fields Condition - Issue type (field) equals (condition) Support (value)
  5. Add an Action, Edit Issue - choose the Components field, and set the required value
  6. Give the rule a name and activate it
^ This should provide the desired outcome.
See more information about Automation for Jira on these pages.
You can also create this as a global (multi-project) rule if you prefer. You'll need to be a Jira Admin, then access Automation via Jira Settings > System > Automation Rules.
Just remember that global rules have an execution limit per month - whilst project executions are virtually unlimited.
For premium, the execution limit is 1000 executions per licensed premium user, per month, across your whole instance (eg. 200 users = 200K executions).
Ste
Thanks!
Like Ste Wright likes this
