Export Project setting
Harry Corte
February 7, 2022
Is it possible to make an export of the Project Settings and use it as an import for a different project?
The other project starts with the same Project Settings
Mark Segall
Hi @Harry Corte and welcome to the community!  Even easier is that when creating a new project you have the ability to use a shared configuration which essentially does the same thing.  See the attached screenshot:
Harry Corte
February 7, 2022
Thanks Mark, it worked!
