×We need to extract a report from JIRA that include comments while issue is in code review status.
I want below field in report
JIRA- ID, Code Review Comment, Comment By, Commented Date, Issue Type, Current Status of Ticket
You can do this with Better Excel Plugin.
There is actually a pre-configured export type that will list the columns you selected plus the comments per issue.
If I correctly understand you want to export only those comments that were posted while the issue was in a specific status. That is also doable by applying a custom filter (predicate) to the comments collection before exporting that to Excel. The predicate should find out the periods from the issue change history during which "status = YOURSTATUSHERE" and match those periods against the submission date of a comment.
For scripting please see: http://www.midori-global.com/products/jira-better-excel-plugin/documentation/scripting
I'm actually getting ready to do an export of issues from one JIRA site at a vendor's cloud instance into our JIRA cloud instance. Has anyone tried to import a xls that this tool exported?
You can't in native JIRA. The comments are in a single field in the database. There may be a plugin that allows it.
Kindly Let me know the plugin name or link. I am not able to find the plugin.
