Export options not the same in Project Issue view vs Search All Issue view.
Is there a setting to make these the same? I find it odd that all options are not available everywhere in Jira.
EX Search All Issues Export options
EX Project Issues Export options
No, there is no option to make them the same. The reason why you have two additional export options is that in the all issues view you can configure what columns are visible in that view, and that is what those two export options are covering.
In both Project Issues view and Search All Issues view I can select which columns that are shown. So this answer holds not water for me.
Correct, but the project issue view is different from the All issues view. The project issue view is based on the new search experience. Hopefully by the time the all issues view is replace with the new search experience it will have the those two options to export too.
Hi @Brent Clark
You are right.
You are right as well forgot that you can change the display options on the project export only with the fields available on the project.
