Export to Jira Issues to CSV/timeout
Dong Yun September 23, 2019
A user is attempting to export over 3500 issues to CSV. When the user attempts to export a data dump (all) the file begins the download process in the browser and then fails. It appears to be timing out.
The user will do the same export but will select the fields she needs and she is able to download.
On a side note, I am new here but assumed I could change the label to have this question pop up somewhere else. Please move this question if needed to the appropriate location.
With that said, I am a new user using experimenting with JSD/Core/Software.
Thanks!
2 accepted
Dong Yun June 25, 2020
We also learned that limit can be increased.
Esther Lansbergen January 14, 2021
Hi Yun,
Can you please share with me how to increase this limit?
Kind regards, Esther
Dong Yun March 4, 2021
I wish I knew, our Administrator let us know about it.
Like Dario B likes this
Dario B
September 26, 2019
Hi @Dong Yun ,
Can you kindly let us know if this is for Jira Server or Cloud?
If it his for Jira Cloud, it can be the case that to export the whole fields takes more than 60 seconds and then our proxy cuts the connection (having more time, the export would have been successful).
This is a known bug tracked as:
As written in the workaround section:
Workaround
Please vote for the above bug ticket and set yourself as a watcher so that you will be notified in case of any update/progress. The bug will be addressed according to the Atlassian Cloud bug fixing policy.
I hope this helps.
Dario
Thanks for the information.
