Hello All,
I'm looking for some suggestion/plugins which supports my request to export Jira issues without comments into word or PDF. Suggest me if any.
Thanks in advance!
Deepak
Hi @Deepak
As @Fabian Lim correctly mentioned, Better PDF Exporter is one of the best ways to export your Jira issues to PDF documents with or without comments. You can also decide on the layout: export your issues in a table format or export each issue into separate pages.
Give it a try and reach out if you have any questions!
(Please note that I'm part of the team developing Better PDF Exporter.)
Here is one that you can use: https://marketplace.atlassian.com/apps/5167/better-pdf-exporter-for-jira?tab=overview&hosting=cloud
