Facing connection KO issue, when integrating Testlink 1.9.17 with JIRA using rest interface. Can someone help me out in resolving the issue.
"connection KO" is meaningless to us. Could you describe the actual problem?
Thanks for your reply. I am trying to integrate JIRA 7.0 with testlink (Test Management Software ). It supports only REST API for communication however when i am trying to establish a connection, it is failing, what could be the possible reason for the same.
There's a lot of reasons a connection could fail. What is the error message?
Facing similar issue. in testlink event log, below is the error I am seeing
SOAP Fault: (code: WSDL, string: SOAP-ERROR: Parsing WSDL: Couldn't load from 'https://xxxxxx.atlassian.net/rpc/soap/jirasoapservice-v2?wsdl' : failed to load external entity "https://xxxxxx.atlassian.net/rpc/soap/jirasoapservice-v2?wsdl" ) |
i am using test link 1.9.18
