Facing problem while authentication with Rest Api using node js
ABHAY D DESHMUKH
February 15, 2019
Hi ,
I am using
 https://mydomain.atlassian.net/rest/api/2/search?jql=project = 'project' AND issuetype = 'story'
query to retrieve data from JIRA.
My node js code :
const requestObj = {
headers: { 'content-type': 'application/json' },
url: "https://mydomain.atlassian.net/rest/api/2/search?jql=project = 'myproject' AND component = 'mycomponeny' and issuetype = 'story'",
auth: { Basic: ('myid@project.com:vtrhtututitittitfterew').toString('base64') },
 Accept: 'application/json'
I am getting error "auth mechanism is not defined"
I have also tried
auth: { bearer: ('myid@mydomain.atlassian.net:vtrhtututitittitfterew').toString('base64') },
 auth: { Basic: ('myid@mydomain.atlassian.net:vtrhtututitittitfterew').toString('base64') },
But I am still getting error "auth mechanism is not defined"
your help is highly appreciated.
Abhay
Warren
February 15, 2019
Hi @ABHAY D DESHMUKH
I use C# as opposed to js, but the differences that I notice are :
  • I use Authorization and you seem to use auth
  • I use Basic, so stick with that one
  • The format looks like
    Authorization: Basic vkd2FycmVuLmxld
Hopefully you can get something out of this to help you
ABHAY D DESHMUKH
February 17, 2019
Thanks Warren
The format I have used is mentioned in Jira rest api documentation.
I have tried with Authorization and basic and it work properly.
Abhay
CrazyAs5assin May 13, 2020
Hi can you let me know what was the Authorization header you used . I tried but it's not going through
Warren
May 13, 2020
Hi @CrazyAs5assin
So my header looks like
Authorization: Basic encodedDetails
where encodedDetails is the 64 bit encoded combination of the Jira e-mail address and the API key.
If this doesn't help you, you'll need to give more info about what you're trying to do, what you've done and what problem you're facing.
