Few Features are not visible in Scrum Backlog screen aligned vertically, left side of the board. Also the search (magnifying) icon to search from the vertical list of Features are not showing the features though they are on the list.
Hi @Yatiraj Sharma ,
first of all please check that status of thos e features has been mapped with a column in the board.
Fabio
Hi All,
Anyone has any solution to above problem ?
Are you using any third-party app that enables this FEATURES search box?
I don't have this on my scrum backlog in Server/DC.
No it's Atlassian only where you can change it to Version/Epic or Version/Feature..
you see at the left had side vertical wording as Versions
