Field is required even if it is not required in the field configuration
Wan Ahmad Mustaqim Bin Wan Azmi April 26, 2024
I have this one field called 'Actual Result'. In the field configuration, it is marked as optional but when I go to creating an issue with this field, it shows as required. Other projects with the same field configuration shows optional and it is working as intended. I have tried reindexing both project and Jira to no avail.
Any ideas to rectify this? It is supposed to be optional.
I have searched around but found one similar post like this but that one does not have any answer.
Appreciate all replies,
Mustaqim Azmi
Victor Law
Hi @Wan Ahmad Mustaqim Bin Wan Azmi
There are a few configurations that could enable the field to be required:
Thank you.
Wan Ahmad Mustaqim Bin Wan Azmi April 27, 2024
Hi Victor,
Thank you so much for the reply. I accepted your answer as the issue was the field was mapped inside Behaviours. Removing the field solved it.
Like Victor Law likes this
3 votes
John Funk
Hi Mustaqim,
Have you checked the workflow to see if there is something there on the Create transition that would make it Required?
Also, can you share a screenshot of what happens if you try to save the issue when creating and the error message it gives?
Hi John,
Thanks for your reply. I have found the culprit that makes the field mandatory.The field was mapped inside Scriptrunner's Behaviour. Removing it from Behaviour solved the issue.
Like John Funk likes this
SERVER
