Field is required even though not on screen
Shamsudeen Shaikh May 16, 2014
I have a custom field (required) configured on a specific screen, However when I try to create a new issue JIRA complains of field being required.
My create screen and screen which has the custom field are different, Also I verified in field configuration "screens" option.
I think the field is getting tied up somewhere, but cant figure it out.
Shamsudeen
Fabio Racobaldo _Herzum_
a custom field that has been defined as required into Field Configuration scheme is required into the creation screen even if it is not present there.
If you need to define a custom field required for a specifc workflow transition (different from creation), you could install JIRA Suite Utilities plugin and add a Validator (Fields Required) for your transition.
Hope this helps,
Fabio
Please, mark this field as option into your Field Configuration Shceme and take a look here for more information about Fields Required validator configuration https://jsutil.atlassian.net/wiki/display/JSUTIL/JIRA+Suite+Utilities+Workflow+Validators
Fabio
Basavaraj Nesargi August 16, 2018
But the required field will not have an asterisk(*) mark by using the Fields Required validator.
Thanks a lot ... That works...
You're welcome. Please mark my answer as accepted.
Fabio
