Hi there,
I marked some fields as required fields but when I create a task this field are not mandatory! How can I change it?
How are you making them required? Are you sure you want them to me mandatory or are you just wanting them to be required during the Create transition?
In Field configuration I have set the fields as required but only for the project. But now I found out that I have to set it in the default field configuration, too. So my problem is now solved. Thanks for your help!
