The figma links have disappeared which was attached to the JIRA Issues .
Even any new added ones dont show up.
It shows design successfully added and then it disappears
My configuration with Figma is corrrect
Have the same problem. We had to reattach every task with Figma links today... However, to prevent this bug, we decided to use "Web links" instead of attaching it as "Designs"
I can't see any disruptions on Atlassian side relating to this.
You might need to see if there's something on the Figma side
Yeah, already talking with community in Figma, but didn't get a response from the support yet. Bug reported on both ends:
https://forum.figma.com/report-a-problem-6/jira-widget-lost-all-designs-links-attached-to-tasks-36873?postid=150912#post150912
Hi Marc
when I contacted figma they don’t know about it
There's a high chance that's it's on the Jira's end as if you go to Ask a question you get this:
This issue is relating Confluence and Jira issue linking. This has nothing to do with Figma.
