Trying to figure out how I can filter for a range of issues based on their key.
For example IOS-1 thru IOS-999, then IOS-1000 thru IOS-1999.
I need this for running an automation on a set of issues - automations have a limit of 1000 issues.
My only workaround is to look for the created date of IOS-1 and IOS-999 and use those dates to create a date range filter
Hi @Stephan Lewis,
You can perfectly use greater than or smaller than with issue keys, like this:
Project = IOS and key <= IOS-1000
That would return the first 1000 issues. And the following:
Project = IOS and key > IOS-1000 AND key <= IOS-2000
would return the next 1000 issues. And so on.
Hope this helps!
You can use a JQL similar to this:
(key >= IOS-1 AND key <= IOS-999)
