Hi!
Could you help me to understand is my request is feasible.
I got group named "GROUP" with member inside (USER1, USER2, USER3) and want to find all tickets assigned to that group members. In JQL I easily can get by following query:
assignee in (membersOf("GROUP")). But I don't get how to do the same in MDX.
Filter(
[Reporter].[User].Members,
CoalesceEmpty([Reporter].CurrentMember.get('Groups'), '') MATCHES '.*developers.*'
This is from an EazyBI doc you can find here: EazyBI documentation
Is this question related to EazyBI?
Brittany
I tried this one, but receive following response:
Formula is not valid:
Member expression 'Filter([Reporter].[User].Members, (CoalesceEmpty([Reporter].CurrentMember.get("Groups"), "") MATCHES ".*GROUPNAME.*"))' must not be a set
Hey,
What version of EazyBI are you running?
I also found this in their documentation.
Calculated members in other dimensions
I'll keep looking for something that might already be put together.
Might this be similar to what you're looking for?
Sorry, I don't have my own test environment for this or I would test it out myself.
Hope we are getting closer to a solution for you.
-Brittany
Thanks, trying this but result is empty, currently I'm waiting for answer from my Tooling team, because it may happen due to we have Active Directory groups instead of JIRA user groups.
Hi @Konstantin Balashow ,
There is no need to create custom calculations to get tickets assigned to some user group. You might want to use the dimension "Assignee Group" on report pages to filter data.
1) In eazyBI import options, tab Additional options, select to import user groups and import data: https://docs.eazybi.com/eazybijira/data-import/jira-issues-import#JiraIssuesImport-Additionaldimensionsforusergroups,intervals,andissuelinkfields
2) In the report, move "Assignee Group" on the report pages. Now you can filter report data by the user group in the Jira (see picture below).
Best,
Zane / Support@eazyBI.com
What type of Atlassian system is MDX?
It's query language in eazyBI, looks like I didn't specify product correctly
