Filter to display a DONE issues by developer in the last 90 days
Suzy Rothwell February 9, 2024
Hi all,
I am creating a filter that displays all the done issues in the past 90 days by Developer. However, since we change the Assignee from Dev to QE, I need to use the "Assignee Was" but I am getting an error that "operator WAS does not support list value for field Assignee".
Here's the filter I am using:
project in (T,P, N) and type in (Task, Story, Bug) and status = Done
AND assignee WAS (xxxa40448d8b9c0068b7dyyy, xxx21151234d44d406d1cg55, xxx47226acaa710068f7a555) AND resolutiondate >=-90D
(I am then looking to export this filter over to a confluence page for reporting but need to nail down the filter first).
Appreciate any help you can offer....
Thank you
Bill Sheboy
February 9, 2024
Hi @Suzy Rothwell
Please try using WAS IN for a list of assignee values:
https://support.atlassian.com/jira-software-cloud/docs/jql-operators/#WAS-IN
Thank you Bill - that worked.
Like Bill Sheboy likes this
Jehan Bhathena
Hi @Suzy Rothwell ,
Glad to know Bill's suggest worked for you, please can you mark this thread as the Accepted Answer, so that it's more visible to the other community members.
