×I want to make use of the Releases feature; however, after many hours of trying to figure out how to add issues to a specific release, I'm stuck.
Everything I've read online says you use the "Fix Versions" field of an issue to assign that issue to a specific release, the problem is that field is not available on any of my issue forms.
I've gone into the Issues => Screens configuration and verified that "Fix Versions" is assigned to all screens.
I've gone into the Default Screen Scheme and verified the field is listed there.
But it still isn't showing up when I create or edit an issue.
Could someone please provide me with detailed step-by-step instructions for getting "Fix Versions" to show up on my issue forms?
Would be greatly appreciated. Thanks.
Here are screenshots of the Bug Issue. And below that is the screenshot for the Default Screen that show the Fix Version field.
Hi Marvin,
What type of project are you using?
You appear to be using a team-managed project, and that Releases are disabled. To enable them use the left-side navigation...
Project Settings > Features and enable Releases.
Thanks, that fixed the problem. Weird thing is even though the Releases feature wasn't enabled, I was able to create Releases. Just couldn't assign any issues to them.
Hi @Marvin Warble ,
Can you please share some screenshots? Did you check if the fields are hidden when empty? You can access the list of hidden fields when empty by clicking on 'Configure' which takes you to the issue layout for the corresponding screen:
