Fix versions (release) in Advanced Roadmaps
jeroen.wilmes
May 11, 2022
I have an Initiative in Advance roadmaps allocated to a release (fix version), will the epic under this Initiative automatically be assigned to that same release?
David Wuth
May 11, 2022
No. You must either manually edit the child epic, or create automation that copies the fixversion from the parent initiative to the child epic.
jeroen.wilmes
May 15, 2022
One more question on this,
How are releases in Advanced roadmaps related to Fix-versions in Jira?
David Wuth
May 17, 2022
Release in Advanced Roadmaps = FixVersion in Jira
Like # people like this
jeroen.wilmes
May 17, 2022
May I summarize this as:
I can make an Initiative in Advanced Roadmap allocated to a Release (let say Release Q4).
I can make Epics in Jira as child of this Initiative and allocate that to the same Release (Q4), although I have to do that manually or make an automation rule for that.
But I can also allocate that Epic to a Fix Version (xxx), different from the  Release of the Initiative.
Both the Initiative and its child have a different Release/Fix Version.
In the roadmap of the Initiative I still can see my Epic although it has been allocated to another FixVersion/Release.
If the dates of the Epic exceed the deadlines of the initiative Release I will see that in de Roadmap.
If that is the case we have full control.
thanks in advance for your answer.
David Wuth
May 17, 2022
My understanding and experience is yes to all of your statements, except for the date exceeding the deadline. I have not used dates in that way so I do not know if that is correct.
One note of clarification: the Release/FixVersion is specific to a project in Jira. The children of an epic may be in a different project, and thus have different fixversion. Same is true that an epic may be in a different project than the initiative. This limitation can make it very difficult to see the relationships in Advanced Roadmaps if you filter by release. See https://jira.atlassian.com/browse/JRACLOUD-66760 and give it an upvote.
Like jeroen.wilmes likes this
