For a specific issue, I want to be able to update only to a specific group, and make other groups read-only. Is it possible? In addition, only a specific issue is in such a state, and other issues are in a reference update state.
Hi @青本 - Welcome to the Atlassian Community!
You should be able to do that with Issue Level Security. Here is some more information on that:
https://confluence.atlassian.com/adminjiracloud/configuring-issue-level-security-776636711.html
However, this is a privilege that can or cannot be viewed,The purpose is that any group can refer to the issue, but only a specific group can be updated. Is it possible?
You can do it on status, in company-managed projects, but it will apply to all issues in that status, not arbitrary ones.
