We are using datacennter (aws) 8.5.1 for few users are facing jira loading problem, so where can i check and how colud i reslove the issue
What are those few users doing differently to you?
for morning times only loading slowly for that users, from my end logged with their credentials working fine, i checked network also , other atlassian tools also working fine , only morning times it working slow for few users, where i need to check and how can i resolve this issue
So what are they doing differently to you?
they didn't do differently, but still getting this type of issue, for few people specially morning times.
They're "yes" differently? That makes no sense.
Could you tell us the difference between their usage and yours?
previuosly they are connecting local network , i suggested them to use other network like jio then it will work for few users for some users not at all worked.
Using AWS(amazon workspace ) it will better , but not much that level , but we can't provide AWS access for every user. they didn't do differently.
I do not understand, I am sorry.
It looks like you have a set of users, for whom Jira seems slow (especially in the mornings).
The difference between them and people who do not experience slowness is that the users who see slowness are using a different network. Is that right?
Yes, but we have 250 users , out of that 10 to 15 people are getting this issue, so if i restart the jira , it will work? , we are using data center and "The Jira server could not be contacted. This may be a temporary glitch or the server may be down" this error we are getting how colud i reslove it we are using single node and single cluster
No, restarting is not going to help.
You have said the affected users are using a different network, and "could not be contacted" is consistent with networking problems, so you should be looking to fix your network slowness.
